Strecker25
- Joined
- Jun 1, 2015
- 100
Short backstory...I have twin AlphaIGenII's on a 290 sundancer. OEM uppers, SEI lowers. We blew the lower gear set out the side of the drive on our stbd side. SEI replaced it under warranty, all seemed well..
We put 10 hours on the new lower and I would notice a very small drop in gear lube level during some trips. I attributed it to air finding its way out and we were close to the end of the season anyway. I would also often see a very faint sheen on the water at the slip.
I have the drives home now and pressure tested them. They both hold 10psi for 24 hours with no issue. If I turn the shift shaft and put any amount of pressure in either direction (FWD or Reverse) I have a leak. This is the case on both of the units, including the one that was not losing lube. I can also pull up on the shaft i would guess a little less than 1/4" but again, same on both units.
From the diagrams it looks like it is simply a large Oring style gasket, so it makes sense that pressing it in any direction would cause air to leak out. I would say that "normal" movement of the shaft doesn't cause a leak, but how much pressure does the shift shaft get put under during operation?
Is this normal, or should the shift shaft keep a tight seal no matter how much you push or pull it? I don't want to RMA the drive again if it is fine.
Thanks! sorry for the long winded question
