alpha leg
dento29
Hi all, can anyone see a reason why i can't fit a alpha leg from a 3.0 engine to a 5.0l engine?
Many thanks
45Auto
Re: alpha leg
It'll fit fine. The gear ratio will be wrong, the 5.0 V8 has much more torque so the 5.0 outdrive is geared higher. You'll have to do something with a new propellor of much lower pitch (which will generally be much less efficient for your motor, which is why it has a different gear ratio to begin with .....) to try to get the max RPM back up where it needs to be for the 3.0.
bigskiohio
Re: alpha leg
he is right but it will work , there has to be somebody that has done this that will tell you results. it will get you on the water.
TilliamWe
Banned
Re: alpha leg
As stated above... a 3.0 should be a 2.0 to 1 ratio, where the 5.0 is at the very most, likely a 1.65. So you would end up with an odd gear ratio, and you'd need a higher pitch prop. It can be done though. My father used his 1.81 ratio drive from a 4.3 when he changed to a 5.7. But he needed like a 27p prop, which he didn't have, and are not all that common. Later, he put a different lower unit on and ended up with like a 1.65 ratio. He was able to use a 25p prop then. Worked just fine.
dento29
Re: alpha leg
Thanks for the reply.
So in terms of pitch, would you say less or more (ratio is 1.98:1) and any long term damage from this?
dubs283
Re: alpha leg
pitch? hard to say, depends on the boat
long term damage, you bet. mercruiser makes different gear ratios for a reason
you're either gonna lug or over-rev the motor and destroy it or smoke the drive unit
putting a different prop on may work in a pinch, but over the long run, the drive is still gonna be spinning the same regardless of prop pitch
your best bet is to order a new upper gear set for the drive, shim it properly and then you know your set-up is correct. why guess?
dento29
Re: alpha leg
Thanks for all your help, what a great forum! ..just want her back on the water and being in the uk-not alot of mercruiser legs come up so if i can make it work then great!
TilliamWe
Banned
Re: alpha leg
You know that SEI lower units are only about $795, brand new, with three year warranties? They are sold right here on iboats.
bigskiohio
Re: alpha leg
i thought the lower is where the ratio is made
cooter2506
Re: alpha leg
I thought all the uppers were the same and the lower is where the ratio change was.
WAVENBYE2
Re: alpha leg
On my Alpha One drive the ratio is labeled on the upper unit, don't know if that means anything.
