alpha lower unit question
dshelly
While replacing my impeller with a kit I noticed the kits water tube was shorter then the original.Also how does the gear oil travel from upper to lower.
crazy charlie
Re: alpha lower unit question
Make sure you got the right kit.There is a small hole in the upper and lower that mate up with a crush oring when the 2 are assembled.Look near the pump housing side and you will find the oil passage.
tommays
<br /><br />they get sealed buy that littel black quad-ring on the penny<br /><br />REALLY INPORTANT<br /><br />tommays
Bt Doctur
never had a kit with the "water tube" in it?
I've seen Somebodies Kits that have that little short piece of Plastic Tube that connects the Copper Pipe at the Impeller Housing......
dshelly
does that quad ring come with most impeller kits?
Originally posted by dshelly:<br /> does that quad ring come with most impeller kits?
I've Never seen 1 that Didn't.....
