Alpha No Trim Limit Switch Connectors
jeb6294
Replacing bellows (Alpha 1 gen 1) so I was replacing the trim limit/sender. Sender is easy enough…I can trace the wires to the rings on the distribution block. Limit switch wire goes into a taped wiring harness and then into the big plug (circled in the picture). Are the connectors taped up in that harness somewhere? I’d rather not rip all the tape off. Instead, could I just cut the wires before they go into the tape and add a couple new bullet connectors?
dubs283
The limit switch wire ends are two male bullet ends that connect to the trim wiring harness normally located near the pump itself
Oem wiring would not have it routed through the main engine harness
