1978 350 260hp mercruiser last spring I replaced the shaft that goes into the motor coupling checked the alignment was real close I wouldn't say perfect. I could pull the tool out and push it in fairly easy but not with two fingers. When I pulled the drive off yesterday it was stuck finally got it off. Checked the alignment still felt good but one of the Orings on the shaft that goes thru the gimbal was crystalized must have gotten really hot the bearing seems ok. Any idea why it got that hot?
