alpha one 5.0 wont start
talies13
i have replaced slave solinoid and spark plugs . engine turns over but just as it is about to start a small puff of "smoke" comes up from under the under head gasket area. i am hoping it is just a gasket problem and not cracked block. any ideas?
Re: alpha one 5.0 wont start
Ayuh,.... Welcome Aboard,... Look closer,.... You can see it, We can't....
wellcraft-classic210
Perhaps a compression test of all cylinders would be of help. If their as a big variation that would indicate a problem in one of the cylinders.
talies13
Ok looks like previous owner did not winterize . Sucks for me! Can I fix cracks with jb weld or is it a total loss.
Ayuh,.... Sorry,... No info, No answers.... I'd Guess she's Junk.....
talies13
Not what I wanted to hear. I guess I will try some weld jobs and see what happens . Thanks for the help!
Don S
If we can't see what's leaking, we sure can't tell you how to fix it, or even if it's fixable. Pictures are worth a thousand words.
rickryder
Yes due to budget cuts they have turned off our crystal balls.......:rolleyes:
talies13
ok sorry about crystal ball shortage. i will take pics and see if boat can be saved. again thanks!
boat can be saved, not sure about the block and heads. please post pics
talies13
Ok . Sorry no pics yet but i do have new info. Looks like engine has been jb welded before. But the white "smoke" is coming from where the exhaust manifold joins the motor. Think it might be clogged?
