Reorandy
- Joined
- Dec 14, 2011
- 23
My '87 Alpha One (0B665929) that I got last year had a slow-medium leak into the bilge last year and I removed the outdrive last fall. Slightly oily bellows. Small "accordion" boot on right side looks fine, no signs of trouble. The water passage O ring was not there, however when I removed the outdrive. Could the absence of the water passage O ring cause the slow leak? Could it be some sort of seal that is letting oil into the bellows? I shined a bright light into the bellows area on a dark night and pulled up the housing and I could see no light shining "through" the bellows, but did notice two round metal pieces on the right side of the inside of the bellows, they looked like some kind of rounded staples or something similar. Are these two rounded metal pieces part of how the bellows is attached or a potential problem? U joint had a slight rusted color, due to the water intrusion. I greased the two zerks that I could find on the u joint with 2 4 C w/teflon (is there another one I missed?) and it came out the bearings, pushing out some kind of brown grease. From the drive spline inward, the first "knuckle" of the u joint flexes in all directions, the second knuckle moves one way but does not swivel the other, causing the shaft to be angled improperly for insertion into the bell housing. The shaft spins when turned and the prop shaft turns, but the u joint spline is askew due to what I believe is lack of mobility in the 2nd knuckle. The u joint and spline is not bent, just rotates funny when the shaft is spun and does not seem to have full range of motion. Is this normal? Does it sound like the u joint is toast/frozen up? 2 4 C seems to be coming out of every housing area on the knuckles when I pump it in. Also, underneath the bellows, directly behind the shift shaft, it looks like an elliptical water entry port or exhaust? This appears to need some kind of tube attached to it that attaches to the bell housing just behind the shift shaft. This "tube" has been missing since I got the boat, with no water intrusion. Just wondered what this is called and what its purpose is and whether its neccessary. Any help is appreciated.
I was all set to go with my new gasket kit, synthetic gear lube, etc when I uncovered these other issues...
