I have a 1985 Celebrity 18' bowrider with 5.7 Merc with 4 barrel Edlebrock Carb. At WOT I sometimes hear a loud popping sound from the carb. I believe its fuel igniting in the flame arrester area. Usually at 3800 rpm and higher after I've been on the lake over an hour or so. It sometimes will pop when I use trim up. Voltage drop maybe ?
When at low speed I also have a idle problem. Whether at idle or up to 1500rpm it will run for about 5 seconds at constant 1500rpm and then drop down to 1100rpm for about 2 seconds then back up to 1500rpm. constant up and down. Idle is set at 600rpm. Help Please. Suggestions?
StevenT
StevenT
