Hello, I have a mercruiser 4.3 with an aplha one gen one outdrive. It overheated for a little bit this weekend. First question, What things do I need to check for? I shut it down when I seen the temp gauge at 200. I have taken the outdrive off and found the impeller was trashed. Thus the reason it overheated.
Second question, Where does the water go after it reaches the exhaust manifolds. I put a water hose on the gimble housing to make sure the flow thru the engine was good and i was expecting it to come out the exhaust bellow but instead it came out two holes on the lower part of the gimble ring.
Am I missing something?
