I have a alpha one I’m trying to replace the bearings in the upper on the drive gear u-joint shaft. My serial no is 0b496372 there is an f stamped by the serial no. That should make it 1.50:1. I even counted teeth drive gear 22 driven gear 20. Looked up part number for bearings for 1.50:1 ratio part number 31-35988a9. The problem is the bearings are 1 7/8” and 2” id my gear shaft is 1 7/8” od. Wondering if someone replaced the driven gear with one from a different ratio. One thing I’m noticing is the number of teeth of drive and driven gear the numbers are reversed on everything I’ve seen. I just need bearings with 1 7/8” id or at least one more. The spacer is quite a bit thinner in the set I ordered. Thanks for any help in advance.
