off course
- Joined
- Jul 24, 2007
- 10
1999 Mercruiser 5.0L Alpha one drive, lost almost all forward drive with no noise or warning.While using the boat yesterday, it all of a sudden would not gain speed.The engine is fine and it goes into forward and reverse normally with no strange noises, but the boat will not go over 5mph @2400rpm(normally 22-25mph).With the console shifter in forward the prop will rotate forward but not backwards, in reverse it will rotate either direction. I didn't try the boat in reverse after this problem came about,(getting back to land was priority#1). I realize we have an outdrive problem, but before going into the drive are there an tips, test, or tricks to look for.Thanks for the help.
