Chopper Doc
- Joined
- Mar 12, 2006
- 43
Ok, I am sure this is a dumb question for you guys but since I don't know the answer to it I don't know if I may have a possible problem. Here goes. First off I have a 2005 Tahoe Q4 Sport. It has a 3.0L Mercruiser Inbd/Otbd with an Alpha One drive. It has a 14 1/4 x 21 inch prop and runs roughly 43.9 mph at WOT at 4900 RPM with just me in the boat. Under a standard load it turns around 4800 +/- 100 at 42 MPH. I am fairly happy with this as I normally do not tow skiers. Gets good fuel usage as far as I can tell too. My question is this. I know it has a flow through prop for the exhaust but at idle with the outdrive lowered the exhaust seems to come out around the gimbal rings. Is this normal? If I run the engine with the water hose hooked up to it I notice that hot water comes out from a hole on the right side of the gimbal ring while some exhaust and water will also come out of the prop and the left hole in the gimbal ring. Is this right for my outdrive or is something broken?<br /><br />Thanks,<br /><br />Wes
