Alpha One gear case cover: 250 ft-lbs??
tcgravy
Manual says the torque spec on the Alpha One gear case cover is 250 ft-lbs.
These are the (4) 12-point bolts on top of the lower unit?? It's like a 3/8" bolt.
RJLeuwen
Re: Alpha One gear case cover: 250 ft-lbs??
WHAT???????????
NO NO NO!!!!!!!!!!!!
Torque is 20 ft lbs
get different manual!!!!!!!!!!!!!!
RJ
Robj
Or maybe 250 inch- lbs. Definitely not 250 ft-lbs
Have a great day,
Rob
Don S
Just out of curiosity, where did you read 250 ft. lbs.????
thedillybar
Found it in a SELOC Mercruiser service manual.
I have no doubt that the listing is supposed to read 250-inch lbs...knew there was no way it required that much. Thanks a lot for the help guys.
Now I just need to get that motor back together...
thumpar
250 inch-lbs=20.8333...... ft-lbs
