Re: Alpha One gear lube issue
should go in easy , how does it drain slow or not at all. sounds lke your vent is pluuged. does yours have a external resevour.
Seems to drain okay (I guess). Never serviced an outdrive before this one, so I don't have a camparison. No on the external reserve.
I also thought the vent would be plugged, but am not sure there is one..? In autos, every gearcase is vented, but not sure about a boat gearcase that gets submerged. So....is there a vent? If so, where is it?
Forgot to add..........I removed the outdrive, and there is a fair amout of gear oil in the bellows.
If there was a clogged vent, pressure built up in the gearcase would push oil past the seal of the input shaft.
Correct????????
