I've installed the new gimbal bearing and now doing the alignment check. I've watched a few videos and know that I should be able to slide the alignment tool out easily with two fingers. (as you can see from the video, I'm not there). Before I go messing around with the engine, I wanted to make sure I wasn't misunderstanding something.
I read some discussions about the gimbal bearing being tilted correctly. From what I understand, you can eye ball it then once it is roughly tilted correctly and you can slide the alignment tool in, you are good to then go ahead with adjusting the engine tilt. Is that correct.
Thanks for the continuing help everyone. Fingers crossed I'll be on the water soon!
