Gerhard Peters
- Joined
- Aug 13, 2019
- 90
A little background. I bought a boat with a bad engine not winterized (I knew this before buying). I have another engine in and running. I also replaced the gimble bearing in the whole engine replacement process.
The last remaining problem is that I can't get the gimble bearing to line up with the engine coupler. I have the alignment tool and have the engine mount adjusting nuts about 1/2 from the bottom. With the old engine, they were at about 3/4 inch. I have spent at least 2-3 and no matter which way I go (lifting and lowering the engine) I can't get it to line up.
When I lift the engine up I get to the point where the alignment tool will not even go into the gimble bearing. When I lower the engine (the adjusting nuts are about 1/2 inch from the bottom) I can slide the alinement tool into the gimble bearing but it does hit the engine coupler. I have tried a little bit of lifting at the time and no matter what it will not line up.
When I put in the used engine I did not pay attention to which way I put the engine couple on to the flywheel. Did I make a mistake? Is there a correct way (lining it up) to the flywheel?
Or what else am I missing? I have done maybe car engine rebuilds over the years but this is the first time I'm working on a boat.
