Alpha one Gen 2 trim issues
nvanzee
I'm having an intermittent issue with my out drive. It doesn't always go up or down. I can hit the switch and I hear the solenoid click but the pump doesn't run. I know it's not the switch as I have a switch in the rear also and it does it with both switches. Anyone have the same issue or able to tell me what to check next?
Bt Doctur
A poor corroded connection in the main pos or neg cable to the pump and the solenoids may be failing to make contact internally
nvanzee
OK, I'll check those connections tomorrow. Isn't it two separate solenoids? One for up and one for down? I wouldn't think they would both fail at the same time
Ayuh,.... Welcome Aboard,.... There's all kindsa wirin' connections at the pump,....
A corroded power or ground connection will effect both up, 'n down,....
nvanzee
OK, so I don't see any corroded wires. I put a test light on the green and blue wires. It does not light when it doesn't work. So, I'm thinking it's gotta be the relay. And it's not always making contact internally even though it's clicking. Any other ways to test it? Does anyone by chance know the part number to the solenoid? It's in an 01 rinker.
nvanzee
Ended up replacing both solenoids and it fixed the problem. Thanks for the help.
