superfets
- Joined
- Mar 6, 2017
- 139
After installing a new impeller, shift cable and bellows I'm trying put put it back together. Problem is I can't get it to shift into forward by pushing on the cable. I can get it to lock into reverse by pulling on the cable. And I can get it to lock into both gears by hand when it's apart. Can you see where I messed up? I can't seem to get the arm to move to the right positions at the bottom of the shaft. It's hard to explain cause I don't know what anything is called.
Thanks for any suggestions.
