joseph.signore
- Joined
- Jun 14, 2008
- 63
Water pump help 1991 Regal:
I recently changed my water pump in my Alpha one /gen one outdrive that cools a mercruiser magnum 350 engine. I installed a new impeller, housing and gaskets. I put everything back together exactly as removed and carefully double checked before reassembling. When I connected the muffs to the outdrive and ran the motor It took about 45 seconds of running the engine at 1500rpms before water started coming out of the back of the outdrive spitting not flowing. After a few minutes of running I noticed the temperature gauge start to redline. I shut the boat off and changed the thermostat then reconnected the muffs and tried again and quickly overheated again.
What did I do wrong? Any help would be appreciated
