Alpha One Gimbal Ring Hinge Repair?
76SeaRay
I just got a used gimbal housing that fits the Y pipe I need. The hinge at the base of the gimbal housing has some damage at the ring pivot hinge. It looks like someone ground it away a bit to get the lower pin out. Do you think it will be ok or should I have the spot TIG welded to build it back up?
Ayuh,...... I imagine it would be just fine, but if ya got access to a tig, I'd fill it in,.....
76SeaRay
Thanks, I will run it by a machine shop to see if they can TIG it...
achris
More fish than mountain goat
That swivel joint boss looks great!
(Remember to etch prime before painting)
76SeaRay
They did a great job. I use the alumaprep and alodine method followed by epoxy primer and urethane topcoat.
