Alpha One Impeller?????????
acdc96
I have a 1986-1987 Mercruiser V8 with a Alpha One Drive...
I need to buy a Impeller for it, IDK what one to buy?
I don't know what generation it is either?
Any help would be appreciated,
thanks in advance
Don S
acdc96
Re: Alpha One Impeller?????????
where would i find the serial #?
also, could i make the gaskets myself?
Don't make your own gaskets!!!!
What's the history of the drive? you doing routine maintenance, changing from an overheat?
Routine maintenance... can get away with just the impeller and gaskets.... An overheat and I would replace housings.
All the part numbers are in Don's link in the post above^^^
I bought Quicksiver # 4696148A8 which includes the upper housing, the impeller and all the gaskets you need... and then some, from a Mercruiser Marine Dealer locally for $41.00.
acdc96
OK i wont make gaskets...
routine maintenance, never overheated
