I am trying to re-install my alpha one and am having some difficulty, it stops just short of the studs. Now when i got the boat it wasn't running and we figured the engine didn't work, so we pulled the engine, not really thinking about it we did not take the out drive off first. It turns out the engine is good, we then took the out drive off, it came off very hard, we had to hit the drive shaft with a hammer and a piece of wood to protect it. Turns out the bellows had a leak and the gimbal bearing was rusted up. Had a shop go through the outdrive and fixed what ever needed to be fixed. We have the engine re-installed, we also just put in the new u joint bellows, gimbal bearing and seal, and are now trying to re-install the outdrive. I do not have an official engine alignment tool but have a pipe that is the same size as the drive shaft. The pipe slides in so the engine should be fairly close as far as the alignment goes. I have the boat in drive and the lower unit is also in the foreword gear and i rotate the prop as we attempt to install. Every thing seems to line up its just that we can not seem to get it to go the last inch. Even with a few love taps
1.) Could something have gotten bent because we took it apart *** backwards? Engine coupler?
2.) Could not being in absolute perfect alignment cause this?
3.) The boat is a 1988 it only has 305 hours on it but could the rear mounts have sagged being it is 22 years old?
4.) Were do i go from here short of just taking it to the shop and paying the arm and a leg?
Any tips/advise are greatly appreciated!!!
