In the fall I noticed drive oil seeping out where the drive bolts on. We had some trouble getting the boat out of the water because the motor would not tilt up. I assumed it hit bottom when pulling it onto the trailer and it jarred something. I took it all apart but didn't see anything. I replaced the gasket and I think an O ring.
Now it is down about 1/4" in the reservoir after sitting for 6 months, so it is a slow leak.
Any ideas where it could be leaking from? Could something be cracked or broken?
Maybe just a sealing issue with the O ring and gasket?
