Richards crappy boat
- Joined
- Jul 1, 2022
- 4
Will a alpha one gen 2 lower shift cable work on gen 1?
Older Merc shift cable part num
Here's why I ask. I have a 87 bluewater 350 mag Alpha one gen one. I purchased a cable from lfs .seirra cable # 18-2603 on my alpha one gen 1 . Moving the cable by hand it goes into reverse and forward gears just fine but I can only get 5 and a half inches between the barrel and end of cable. I'm stumped. Wrong cable? Install failure? Upon looking at the box it's says it's for gen 2. I'm on a steep learning curve with boat mechanics and pretty frustrated!Older Merc shift cable part number 865436A02 goes to newer part number 8M0176524 that fits MC-I, R, MR, Alpha One & Gen II (1978 and newer), https://www.mercruiserparts.com/865436a02-cable-assy-shift
You sir are amazing I appreciate the time you spent helping me out.Looks like the aftermarket part number 18-2603 is the wrong type do to Installation placing into the bell housing as long as nothing else has been modified over the years…You should need 18-2190 as it’s for AFT installation into Bell Housing. “For use in applications using core wire with armored strand construction (No Support Tube). For S.N.6225577 & Up. Condition: New. Product SKU: SIE-18-2190. MPN: 18-2190.
OEM Merc cables have a process to convert installation designs.
