Hey everyone..
1985 26? Searay. 5.7 liter motor with Alpha 1 outdrive.
Had the boat out over the weekend and when trying to bring the boat up to speed, I blew out something in the outdrive. Boat now won?t move.
I will be taking it apart, but as I sit at work, unable to work on the boat, I wanted to ask some preliminary questions?.
The engine revs up, prop doesn?t turn at all, shifter works, looked under the outdrive and appears to be shifting properly, so it?s not the cable. It?s not a spun hub, prop doesn?t move at all.
Here is the clincher ? the impellor isn?t pumping any water into the engine at all, so it?s not spinning? Does the fact that the prop won?t turn and impellor won?t turn give you guys any indication at all of what it could be? Upper drive, lower drive, something with the shift mechanism inside?
