Alpha One outdrive stuck 3/4 of the way using trim switch
mia9516
This just started happening about the same time I ran my boat aground:(. Previously I was able to trim the outdrive through it's full range of motion. Now I am able to trim it down but while trimming up, it gets stuck about three-quarters of the way up. I have to use the trailer switch in order to move the outdrive the rest of the way up. An online search has proven to be less than helpful and I am hoping someone out there has experienced this problem. Thanks in advance.~Milt
Don S
Re: Alpha One outdrive stuck 3/4 of the way using trim switch
Sounds like the trim limit switch is working again. Only not at the right dimensions.
Might want to pull the trim llimit switch off the port side of the gimbal ring and retighten the pivot bolts and re-adjust the trim limit switch. Sounds like the pivot pin is loose and moving around as you trim up and down.
The OEM service manual links are available for download up in the adults only sticky. Section 4 explains them.
mia9516
So I pulled the trim limit switch off the port side of the gimbal ring and all I saw was a bunch of grease looking stuff. Then I took off the cover. Under that I saw a metal tab looking thing. I cleaned it off and put it back together. Is the pivot bolt underneath the switch itself or under the cover? Do I have to regrease between the switch and gimbal ring? The manual is not very clear on any of this. Thanks.
