Alpha one outrive trim wont go down
mattyrich
Does anyone know what to check for on this trim problem...
First of all... 1991 bayliner capri, 140 Mercruiser 3.0 with Alpha one Gen II outdrive (OD577441).
I am trying to figure out whats up with this trim. it goes up no problem but it wont go down... No clicking, Not doing anything, So i would assume its something electrical? My manual is pretty vague on the subject. I guess i should id the pump for you. The complete pump assembly part number is 108120.
What should i look for first?
mattyrich
Re: Alpha one outrive trim wont go down
Does anyone know if there is a manual release on the alpha one Gen. II outdrive. where is it, on the pump? thanks...
dubs283
the pump electrical is controlled by soleniods - just like the slave soleniod on the engine - same part, works the same way (green - down, blue - up)
primary posts (small) activate the solenoid - "click" engaging the secondary posts (large)
no release, crack the lines with a 3/8" flare wrench - you will lose oil by doing this
mattyrich
Where should i loosen the lines from ? outside the boat or inside on the pump? not sure which ones your talking about, Thnks,Matt
dubs283
any line connection will work
best to do it on the outside, that way you can catch all lost oil in a pan - saving you from cleaning the bilge
either one of the two lines on either side of the block under the gimbal housing will relieve pressure
cpt ron jc
dam trim pumps mine wouldnt go up,i took the pump out cleaned everything and stii wouldnt work,mine was the motor and solenid problem 9 out of ten its the motor or solnids,i had mine rebuilt like new for 225 with bracket,a new one runs around 3-400 if your going to rebuild you miine as well rebuild the whole unit while its out i was told it could still be the motor even though down worked,if y want to have it rebuilt check out e bay,trimp pumps,mike alps he rebuilds these things in his sleep,been doing it a long time,mine came out great,good luck
mattyrich
Im hoping its a bad connection or loose wire somewhere. My buddy said it always worked fine before he put the boat in storage. i would never pay someone 200 bucks to rebuild a little pump. If thats the case I will probably just rebuild it myself for that price. not to mention the knowledge you get from diy. Thanks for the tip, matt
cpt ron jc
i hear y but when you spend half of the summer with your head in the engine port,like i have well,now my engine 4.3 is junk,i just ordered a long block from rapido,see how that goes,i will pull engine this week,good luck with trim pump,BOAT...........love it or sink lol
cimy3
[the pump electrical is controlled by soleniods - just like the slave soleniod on the engine - same part, works the same way (green - down, blue - up] [primary posts (small) activate the solenoid - "click" engaging the secondary posts (large)]
Make sure you check the solenoids before draining or removing the pump.
