alpha one prop problem
jeffparlier
Hello everyone, Ive got a 99 Maxum 1900 with 5.0 merc and alpha one gen 2 drive.Im trying to replace aluminum michigan prop.Got a used stainless turbo prop off of a trashed 150 Merc black max.When i put the prop on there is none of the prop shaft sticking out to attach the spline washer to.Can i just leave off the spline washer and drill hole for cotter pin? Dont want the prop coming off! By the way im using the original thrust washer.
Re: alpha one prop problem
Ayuh,... It probably needs a different thrust washer to bolt on properly...
Get the Right hardware, Don't drill the shaft...
jeffparlier
Thanks Bond-o problem is i tried to put it on even without thrust washer just to see if it would work and i still have the same clearance. i know i cant use it without the thrust washer i was just checking for clearance. according to specs for the turbo-1 prop it should fit but when i put it on the end of prop and threads are dead even. i checked last night to see if the hub could be pressed down farther allowing it to seat deeper put i think i could only gain about 1/16 inch and i still would not have any room for the spline washer.question is could i just use a regular washer in front of the prop nut and skip the spline washer thanks so much for your help.
Oldskool
You need the spline/locking washer. It is what keeps the nut from working loose and you then losing your prop.
