I have a 20' Cobalt with a 4.3 LX merc in it. I just lost - at the very least some bearings in the lower unit. Not sure why as there was never any sign of water intrusion.
I currently have a 1.81 ratio and run a bigger diameter 19P three blade or 19P or 20P 4 blade aluminum prop. Rpms max out right around the 4800 rpm mark.
I very seldom run over 4000 rpms though and almost always cruise in the 2900-3100 rpm range.
QUESTION is, I have been looking for a used outdrive and have found a nice 1.98 ratio at a reasonable price, would it work and work well with just going to a steeper pitch prop?
Or do I just bite the bullet and get a Sei unit or wait to find a 1.81 ratio unit?
Can going to the 1.98 ratio and say a 23P prop give me the same or better performance?
Pros and cons of changing the ratio???
thanks
thanks
