Re: Alpha One Stalls When Giving It Throtlle in Reverse
If it's been working fine until recently, it sounds like a cable... (and shaft bushing)
Check the adjustment, but I suspect the top bushing for the upper shift shaft is leaking and allowing water into the slide cavity... Gunge is in the cavity and as the slide nears the end of travel the gunge stops it, tripping the shift interrupt switch.... If it still has the old style bushing, it will most likely have leaked....
Here's a video of the adjustment ->
http://youtu.be/-s_tgevX2aI
Chris........
