alpha one trim not working Problem Solved
truckermatt
Hello,
I am going camping tonight, and now the boat is acting up.
My tilt/trim is not working on the outdrive. When i hit the switch nothing happens... no click, pump struggle or anything.... But i DO have battery power, because the blower and radio still work...
Is there a reset or fuse on the pump..... I looked under the console (dash) and could not find any blown fuses.
I havent used the boat in 4 weeks...
Please help if you can
Thanks
truckermatt
Re: alpha one trim not working Problem Solved
Sorry for the post. the problem has been fixed.... It turns out the battery was drained a little, causing the pump not to work.... but it still had enough juice to power the radio......
All is well now... Thanks
