Anyone have any past experience using a speedi sleeve on one of these U joint yokes to stop it from leaking?
Every year I have been having issues with one of my drives leaking oil because it's got a bit of a wear on the shaft where the seal rides.
It will hold 15psi for a week on my stand in the garage, but every year it's the same thing, I take it out and the u joint is wet with gear oil. Hell, it's still holding pressure on my bench for a day or two before it bleeds off 5 psi or so. I pressurized it Saturday to 15psi and today when I left for work it was only down to 9psi.
I'm figuring a speedi sleeve would solve the issue. Loooks like the cheapest and easiest solution from what i'm seeing.
Yes, the seal itself has been changed...every year I put a new one on it and cleaned the surface with 800 sandpaper. The groove is barely noticeable, but it appears to be bad enough to leak under usage but not bad enough to not allow the drive to hold pressure on the bench.
Anyone do this and if so,how did it work out?
Also, if anyone has the part number to the sleeve it would be appreciated.
