andrewterri
- Joined
- Jun 25, 2014
- 437
Teaching my friend how to check alignment and change an impeller on my old boat I sold him. It is a 89 mercruiser 3.0 with an Alpha One Gen One. Despite telling and encouraging him to do his maintenance each spring (Check alignment, gimbal bearing, ect.) he did not do it and he has learned his lesson that even if you dont use the boat often to still do your maintenance. He is in law enforcment and does not get to the lake often so last year the boat only had 4 boating days. The problem now is the drive will not come off. Six bolts out and selector in drive, but the engine has came out of alignment so bad the motor is on the shaft. He was aware and the reason I sold the boat was the wood the motor mount sits on was rotted and the boat would not hold alignment. I never trusted the boat with my family despite being a good boat. I was afraid the engine would bind while running and twist off the mounts. We tried adjusting the motor to get the drive out and after 1.5 hours of trying it was clear that will not work. What my thought is not is to use a chain hoist or maybe a jack. What do you guys think? How can we get this drive off?
