Alpha1 Gen2 Removal Q
Goldfish
Never removed the whole lower unit. Dealer says make sure drive is in forward then remove 5/6 bolts. I bought a gasket kit too for when i go to put it back on in the spring. Anything else i need to know? d:). I dont plan on rebuilding it, just removal and repaint.
John_S
Re: Alpha1 Gen2 Removal Q
Disconnect the speedo pick-up line before removing the 5/16 bolts. Also need to pop the caps and clips on the rod that holds the hyd cylinders. Remove pin. You should read the online service manual first: http://www.boatfix.com/merc/Servmanl/14/14cover.pdf
Sorry Don, you must type much faster than I!!!
EDIT: Deleting the offending smiley face
Don S
Not sure how your post appears to you, but here is what I see.
I also had problems posting and getting it to show up about the same time.
Look at this thread.
http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=24;gtid=1197580
Don S
Now, How was I able to post inside of John S's post. ? ? ? ? ? ? ? ? ? ?
