back ground.....boat is a 1988.......3.0 140 horse (fresh rebuild) alpha 1 out drive.......
wile rebuilding motor i check gimble bearing....was bad and i replaced it......figured since i didnt know when the impeller was done, and out drive was off why not change it. Good thing i did as one of the blades was about to come off.....took her up today had alignment checked marina told me i was dead on....so ok now time to put out drive back on right .......lol ....... that is way easier said then done.........fought her and fought her finall got it all the way one put the center 2 nuts and washers back on........now for the issue
i can get shift cable to silid all the way out but when i do this it does not go into gear (can spin prop both directions) push shift cable in all the way and i hear a "ting" down in the bottom portion of the out drive and it will only spin in a clock wise rotation and her a clicking noise wile doing this.....it will not spin in a c c w rotation
what gives????
i am assuming that there is somthing that is out of adjustment here but i dont know there to begin to look or what it could be here. i am so close to getting this thing fired up and and maybe wet this year. as you can imagine this is ver frustrating but at the same time a learning process as well so any insides as what i need to check or adjust will get very greatly appreciated and many thanks
