alternator on 1978 70hp johnson?
is there a alternator on my motor to charge the battery? I have a 1978 johnson 70 hp seahorse 3 cylinder
reason is i took the boat out and the battery had no charge to turn over the motor and we had to boost it--this wasnt a problem last time i took it out
Daviet
Re: alternator on 1978 70hp johnson?
Yes, it has a charging system. The alternator is under the flywheel and has a rectifier bolted to the block. To see if ti is charging, put a volt meter on the battery and note the voltage, start the engine and run it at 1500-2000 PRM and see if the voltage goes up.
i have a meter--im not sure what setting to put it on to test this-im not that familiar with meters
Daviet
If it is a analog, needle tpye, does it have a 0 to 16 volt setting, use that. If it is a digital, it should have a volt setting, use that one. Make sure you use the DC volt settings, not AC.
