I have a 97 150 fast strike and have noticed that my battery doesn't seem to be getting a charge from the motor running because after I use it I put my charger on the battery and It takes a while to charge. Is there any way to test or what else would be affected if my alternator was bad. Would the motor even run if it was bad? Does the ignition and pumps run off it?
