So I've had the boat (OMC 120) in the water and hooked up a remote voltage meter to the coil so I could monitor while trouble shooting. My basic problem I'm trying to overcome is that once warm the boat will stall at idle and won't re-start until it cools down unless I use a jumper wire from battery to coil. Most of the season the boat would fire up just fine when first splashed. Last two times I had to use the jumper wire from the battery to get her to fire. It appears that the 12 volt feed from the starter is not doing what it is supposed to. When I turn the key on I have 11 volts at coil, when cranking it drops to next to nothing so I expect the starter needs attention ( spins the motor no problem ...just no fire). Once running the coil receives a touch over 12 volts and stays consistent (a bit higher than what I was expecting). The coil does not get overly warm as I can still place my hand on it. When I idle down the voltage drops and the engine stalls out when the voltage hits around 10.5 volts, placing me in a precarious position at times. Had the engine cover off while running and noticed the lower mounting bolt of the alternator had backed itself out about an inch and half. The nut had come off and the alternator was shaking more than it should have. Managed to get that problem fixed and it seemed to hold its idle better than before but it still died on me. I think the starter is my issue for not re-starting and getting the voltage to the coil and am planning on pulling it and getting it rebuilt/checked over but I'm not sure why I'm stalling. Perhaps the shaking of the alternator has worn out it's bushings and it to needs a re-build/ replacement. The voltage seems to be there but is it possible it is not producing the amps it needs?. Any thoughts or suggestions on how I can keep this engine running at low speed?. I have replaced the points, condensor and the coil is new, wires, boots and plugs all appear to be in good shape. This is my second season with this boat and this problem started at the very end of last season. I've spent this season chasing this gremlin and have already been through the fuel system. Thanks in advance
