1980 Aristocraft I/O - 2.5L mercruiser engine. I attached a photo of a large harness connector. Coming out of this connector, are all of the wires that run to the front of the boat - dashboard, bow light, breakers, etc. I removed and rewired everything forward of the engine (left all engine wiring in-tact). Everything is functional, EXCEPT I can't get the alternator to charge without it bogging the engine.
I have three thick wires coming out of that connector - thick red, thick black, and thick orange. Black is ground. Continuity test tells me that the orange is from the alternator BAT terminal, and the red is from the S (sensing) terminal. However, when I connect both to Battery positive, the engine bogs immediately and idles rough - almost like it's down a cylinder. It revvs up fine, and charges fine, but idles like crap and the alternator gets crazy hot to the touch (not sure how hot is normal). If I disconnect those wires, it idles beautifully (but doesn't charge the battery obviously). Tried hooking up a dummy light between the sensing wire and battery terminal (like a dashboard idiot light), but it doesn't light up with ignition on / engine off like it's supposed to.
Alternator is brand new - actually my second brand new one. Battery and coil also brand new. Coil is getting proper 9V through a ballast resistor.
Any ideas? I'm assuming it's not normal for the alternator to create that much drag on the engine, so I'm completely stumped. Would love any thoughts. Here's the connector I'm referring to:
