Re: Alternator
When I replaced my alternator ARCO had an advisory with it to change the wiring slightly.<br /><br />It said that the 3rd wire coming from the key switch is the sense wire that controls the regulator. This wire runs up all the way up to the ignition key and then back to the engine.<br /><br />On older boats corrosion and the longer run can add resistance to the circuit and mean that the sense voltage is lower than the actual battery boltage.<br /><br />Since the alternator uses this wire to control the voltage, to make the sense voltage correct the alternator can be tricked into putting out a higher than normal voltage to the battery. This can cause overcharging.<br /><br />They reccomend removing the sense wire from the key switch, taping it up, and running a jumper from the alternator output to the sense terminal.<br /><br />I did that and have been happy
