Re: alum hull anode
I've seen brackets welded to the transom, below the waterline of course and as close to the bottom of the hull as possible, that you can mount the zincs to. As bayman states, it depends on the surface area of the hull as to how much zinc you need. Although you can use other materials for aluminum, zinc works great.
