OK, its cold here in NY, so idle minds tend to read, and formulate many questions
<br /><br />I am planning a 2 to 4brl upgrade on my '97 5.7L mercruiser, raw water cooled. I am using the Edelbrock Performer 2104, and plan on a weber/carter/edelbrock 600cfm marine carb. I boat only in fresh water, so in general, the aluminum manifold should not be an issue. The Adirondak water where the boat is moored all summer, is rated as slightly acid. I suspect that is not a good thing for aluminum. <br /><br />I am planning to paint the exterior exposed surface of the manifold, and use an aluminum primer and black merc paint, similar to the procedure for painting outdrive. Is it worth priming and painting the internal water passages? or possibly using something else? I do have a concern if the paint peels off in large chunks, and possibly plugs passages. Probably not much more risk than rust scale or impeller chunks? Thoughts? Experience?<br /><br />My experience many years ago with cars and aluminum intake manifolds, leads me to believe that heat percolation to the carberator will/could be an issue, especially after shutdown/heat soak. I plan on using a good quality intake manifold gasket and block off the egr passages (the carb has electric choke). I will also use a spacer between the maifold and the carberator, but haven't decided between the edelbrock dual plane heat spacer or standard 4 hole square bore spacer. The water I boat in, only ever reaches high 70 degrees, air temp 80's, but ussually cooler than that. Will blocking off egr and carb spacer make things too cold, leading to rough idle? ie maybe use the restrictive egr block-off instead? <br /><br />Anyway, you see that I have too much time on my hands, and thinking way down in the weeds. :0 I'll hold off on my carb jetting/metering rod study and questions, for another cold NY weekend.
