ALUMACRAFT 16.6 semi v Rebuild. -Nautolex-Aluminum Paint-Deck-DIY
CaptainD101
Had this 96' alumacraft for a couple years now and just love the hull and 40hp tiller. Really gotten lots of use over the past couple years and want to bring her back to life .
83mulligan
good luck with it. I'm in the process of doing some of the things you are talking about.
CaptainD101
Pictures are up. Already ripped out lots of decking. Ive viewed many posts of guys using the nautolex flooring and very satisfied with their finished results. So hopefully I will have similar success.
INTERESTED in any posts of people using alternate material for deck flooring besides wood. I would like to lighten the load of the boat by using something besides wood. Maybe a composite, or even aluminum sheet metal.
Also If i go with wood what is the purpose of sealing the ply with fiberglass resin as Ive seen in many posts? ( member with best looking decks were done this way.)
All finished with this rebuild for those of you that followed
18ft aluminum, foam,drainage, deck, paint. Rebuild
Watermann
Hey Cap, nice looking tin you got there! :thumb:
On the decking, aluminum sheets are expensive and weak which means you have to put in a bunch of floor supports. Then you have to cover it, slippery when wet and hot like a skillet. I reccomend using 1/2" marine ply that has 5 layers and is really strong but it does flex some when walked on.
I use spar to seal my ply rather than resin and once covered I'm not sure how good looking wood will matter. Nautolex is really good flooring and pretty easy to work with unless your trying to wrap corners with it, then it's not so much fun.
CaptainD101
No Title
This is my 94 evinrude 40hp tiller.
Runs awesome. Starts right up and never stops.
I did a full motor tune and paint when i first got it, so no work needed here.
CaptainD101
No Title
Here some of my progress.
Used every option of sander and grind wheel to finish the prep work.Decals were a pain to remove.Ready for paint!
Received my 635 epoxy and going at the decks while I wait for Nautolex shark grey. Im putting order today!
Bwana Don
Went with wood eh?
Tiller, does this mean you walleye fish?
CaptainD101
No Title
CaptainD101
What would a jackplate do to the performance of this boat? Im adding a new minkotta riptide 55 and considering an atlas micro jacker. Friend from gander is going to get me 20% off so I was considering the purchase.
CaptainD101
No Title
Heres my progress. Im actually a bit further along than this.
My stereo came in today. I got clarion 400w and 4 100w pioneer marine 6.5.
I built custum decking front and back I will post picks soon.
CaptainD101
No Title
Got the stereo installed and finished all the deck framing. Should have every thing together tonight and maybe mount the motor. Hoorah!
CaptainD101
No Title
CaptainD101
No Title
greenbush future
Jack plate would be an interesting addition, though I've never seen one on a tiller before. What are you trying to accomplish?
CaptainD101
No Title
Took one test run on the lake Sun. Then took Mon. off work and went 30miles on Indian river. What a nice day.
Heres the before and after the main work. Still going to add some things. decals,LED lighting, and add aluminum trim in some areas...
