I have a 1997 Magna 165CS with internal 15-20 gallon gas tank (under the flooring). I suspect I got a 1/2 tank of bad gas and unfortunately need to drain the gas tank. Other than sucking it back out the fill cap (which is in the middle of the transom) is there any other easier way?<br />A friend at work suggested find where the gas tank sending unit is (for the gas gauge) and there should be an easy access "snap cap" you can remove and suck the gas from there (rather than through the fill opening with a long hose). Looking for advice and suggestions. Thanks.
