alumicraft hole repair
brothere
Hi, I have a 1978 alumicraft 14' fishing boat and it has a hole (above water line) in the front left side...the hole is from hitting the corner of a dock...it kind of looks like an aluminum can that has ben hit with the claw part of the hammer...not quite as bad as that but I have to say that the hole isn't clean...I was wondering if there is any easy way of repairing (patching) holes like these...is there any sort of epoxy that I can get or something similar? thanks a lot
Boilermaker
Re: alumicraft hole repair
MarineTex>>>a PASTE epoxy>>>the Gray colored one is for metal & is machinable.
brothere
thanks for the response....where do I get this marinetex???
brothere
nice...thank you very much...now to decide how much I need :)
RichP1269
You may try using the aluminum boat patch from Cabelas. I used it to repair a 3 inch tear in my old jon boat. Comes in stick form and is applied by melting with a propoane torch.
brothere
sweet....that stuff is much cheaper...that should do the trick though it may not be as good as the other stuff...but that doesn't matter, I just want the hole patched up and besides, it is above the water line...thanks a lot richp1269
surfdaddie
Use Marine Tex IT WORKS. I have fixed many holes with it on aluminum boats
phatmanmike
i used marine tex on the botto9m of my 14foot jon and it ripped right off. now i have a 3 inch loing by 1/16" crack i need to do again. no marine tex this time.<br /><br />i honestly dont know WHAT to use, as i have no welder.
dajohnson53
You could also patch it with a a piece of aluminum with some 3M marine adhesive/sealant or you could rivet the patch on and seal with marine sealant. Being above waterline gives you a bunch of easy, cheap options.
one more cast
don't forget about good old JB Weld in the tube from any auto parts or hardware store. However those sticks from cabalas do work well.
