Hi,
I got a Mckenzie boat that needs some love. I got the bottom, sides, and top stripped. It did not leak before but I found a few rivets with silicon around them. I think I should coat the bottom with something before I paint. I have looked around and see many people suggest Gluvit. It this a good route to take for the bottom of the boat? And if so what paint brand/type would be suggested to go over the top of the Gluvit? I was thinking about painting the bottom water level side and leave the top of the boat aluminum unpainted. I have looked around for paint types and there are a large number to pick from. Looking for some suggestions. Thinking about painting the bottom white.
Also the transom needs replacing. I have found several threads with images and some info. Does anyone have a favorite thread for replacing a Aluminum boat transom? It would be my first time doing this and feel I can handle it with some instructions. Any tips for remove of the rivets/where to start?
As for the inside of the boat, any tips for paint removal and what to repaint it with? It is the original paint inside. I used chemical and some hand wire brushes to do the outside/under. I have a angle grinder that could be of use. I was thinking about sanding the outside/under with a sander to have a bit of grip for the paint.
Thanks for any tips or links, [h=1][/h]
