aluminum bonding question
MASTERBrian
I recently had a welded bimini top bracket come loose from the frame. I plan to either use a self tapping sheet metal screw or rivet to re-attach the bracket to the frame until I can have it welded or buy a new frame.
1) which is stronger bond, JB Weld aluminum or an epoxy made for aluminum? Don't have either on had, I don't believe so have to purchase one of them.
2) which is better the screw or a large headed aluminum rivet?
smokeonthewater
x3 rivet all the way... as bondo indicated don't use ANY adhesive if you plan to weld later
