Donald Allard
- Joined
- Sep 11, 2006
- 2
I have a 1989 Sunbird Corcica 175 OMC Cobra sterndrive with a 2.3 Ford engine. There is an access port in front of the engine box on the floor. I removed the round access cover exposing the top of the fuel tank. It's plastic. Mounted there is the sender unit and an aluminum elbow fitting with an anti-siphon fitting . the barbed end is attached to a rubber fuel line. the aluminum fittings are corroaded and broken apparts. the aluminum plate for the sender is corroaded and crumbled when I remived it. Any one know where I can get replacement parts? Should I use brass or aluminum? Why did these parts disintegrate? Also 6 inches of the rubber fuel line are in this area and swell up. The part of the line that is outside this area is ok. I replaced this line with one that a boat mechanic told me was for an enclosed space. Every year I have replaced this line.
