aluminum gas tank repair
tfret
I pulled the belly tank out of our 1984 ski boat today. I had already planned on replacing the filler hose and vent hose. Since I had the deck up to access the hose connections on the tank, I decided to pull the tank out for inspection. What I found are a few spots, mostly on the bottom, that appear corroded and pitted. They don't appear to be leaking at all, its mostly surface corrosion. Some are pitted deeper than others. I was wondering if there is a sealer I can paint these spots with to repair them. Maybe some type of expoxy coating or something?
zbnutcase
Re: aluminum gas tank repair
And then after you are done with the product in the link above, a good heavy coat of paint will help buy it some time also.
tfret
Is that like JB weld? Wonder if I can get it locally anywhere. I'm guessing a good oil base paint over it all afterwards would be good. I forgot to mention, fresh lake water application.
mkast
For adhesion, clean the tank with something like aluminum jelly.
I have used the All Metal, easy to work with, I haven't used JB Weld.
A two part epoxy paint might be better, it's aluminum.
dockwrecker
My favorite radiator shop has "boiled" out several tanks for me and internally sealed them with a fuel tank epoxy. Ran about $120 for the last one I had done. Never leaked again and some of them were pretty pin holed. Then I guess you can do whatever to make the outside purdy again!
