I_prefer_tractors
- Joined
- Jun 24, 2010
- 21
I tore apart the boat in the past week. I finally got all the foam out today & washed it with 50/50 vinegar/water mixture. I found 2 leaking rivets + one small section of seam that needs a little gluv it love. My question is... I've got white powder EVERYWHERE on the inside of the hull. I forgot to take pictures today but here is from yesterday. There are a coupe of areas that have small pits in the hull. Nothing too deep. but its white powdery everywhere. I thought the vinegar + water mixture would fix it and it did not. Someone told me I need to cover it with POR15. at $150 a gallon that seems steep. Are there any other options that are more reasonable? Can I just cover it with a self etching primer? What are my options? I am not really worried about the limited pitting in the hull. Its very shallow.
(photo from yesterday its been cleaned up a little more since)
http://i.imgur.com/bH2SP.jpg (for more zoomed in look you can click here.)
My other question is about the transom aluminum. There was a TON of water trapped. As you can see in the photo Its been wet. The transom wood was absolutely soaked. I got most of the color(rust) off of the aluminum. But there is a decent amount of pitting. Do I just fill those spots with JBweld? Do I need to buy por15 for here too? What alternatives do I got?
Thanks
Thanks
